[SOLD] Versalab M3 Grinder
This is the original Versalab M3 grinder that was reviewed here on HB back in 2005. It uses a unique combo of conical and flat burrs. It needs an upgrade. Versalab offers an upgrade kit to this grinder which includes a motor and electronics upgrade and 2 new belts. Cost for upgrade: $495.00. I'm including 2 brand new flat burrs.
Price: $650. Pickup only, in NYC.
Highlights
Conical burrs combined with 68mm. flat burrs. Total grind path of 40.6mm or about the equivalent of 96+mm. flat burrs.
The burrs are a combination of conical and flat. The beans are dropped into a conical area where they are broken into small pieces. These pieces are then small enough to enter the flat burrs to be finished ground to the chosen size. This is a compact burr set with a long and easy grind path, minimizing harsh treatment of the coffee and producing fluffy non-oily grounds.
All the coffee entering the grinder leaves via the bottom funnel in a circular fluffy deposit into your portafilter.
Highlights
Abe Carmeli
