Dragonfly Crema Dolce discussion
Good morning HB,
After the 2020 list of best coffees came out I realized I was not familiar with many of the roasters or their products. One coffee that kept coming up in a few threads was Dragonfly Crema Dolce. I decided to pick up a kg. It's now 7 days old. I have been pulling 18/34 25-30 seconds with 6 second pre infusion via 18 g VST basket At 199 degrees.
My first impression is that it is "OK". Light color with thick body. My Shots are decent and balanced with a hint of bitterness up front, followed by slight cinnamon and mild sweetness and the finish has a slight Lemmon zest to it. I'm not sure if this is the typical experience or not. I'm not sure how to tweak this blend from here. Usually I can pin point a taste defect but there is not an obvious defect. If anything it's a little on the bland side. So I'm considering updosing to the roasters 21 g recommended dose and pulling 38g in 30 seconds to see if there is a difference.
I am by no means giving a bad review but this blend is not exciting me.
Any comments concerns or advice would be appreciated.
Joe
I tend to pull it at a 2:1 ratio myself. Not that you are super far off from that, but worth a shot. Little longer shot time maybe too. And as you said you should definitley updose if you are finding it bland.
That said, this isn't a knocks you out with crazy flavors kinda coffee. Its firmly in the forgiving "comfort" category.
- JohnB.
While I wouldn't consider the shots I'm getting from the latest batch to be bland I'd say that your tasting notes are pretty close. I've bought Crema Dolce 4 times over the past few years & I'd say the first batch was my favorite. With that one the cinnamon spice was much more noticeable then in any batch since.HotLava wrote:
My first impression is that it is "OK". Light color with thick body. My Shots are decent and balanced with a hint of bitterness up front, followed by slight cinnamon and mild sweetness and the finish has a slight Lemmon zest to it. I'm not sure if this is the typical experience or not. I'm not sure how to tweak this blend from here. Usually I can pin point a taste defect but there is not an obvious defect. If anything it's a little on the bland side. So I'm considering updosing to the roasters 21 g recommended dose and pulling 38g in 30 seconds to see if there is a difference..
Truth be told I was a little disappointed with the current bag but it still produces a tasty shot.
I'm using 17g doses with a yield in the 28g-30g range. Pulling it anywhere between 198*F-201*F. Best shots have been on the cooler end of that range.
LMWDP 267
After my first 2 doubles I did jack it up to 200 which toned down the sour lemon peel flavor but brought the bitterness up a little. At 199 it seems more balanced. Dragonfly recommends 21 grams in 38 grams out which is a 1:1.8 ratio. So I have been using 18/33g as a target which is also 1:1.8. Seems most like it at a 1:2.
It's not bad but usually I know when I'm not getting all I can from a new coffee. But with this I think it's as good as I can get it.
I'm going to use my 20g basket and try 21/38 by comparison.
Joe
I'm in the same boat. By no means would I consider it bad, just wasn't quite what I'd expected.
Out of curiosity, anyone brewed it as filter? I still have almost a bag left and have since switched to Nicoletti for espresso, so I was hoping to find another use for it.
- JohnB.
I haven't but don't see why it wouldn't be good brewed. In the interest of further research I'll try it as an Americano in the morning & report back.tv79 wrote:Out of curiosity, anyone brewed it as filter? I still have almost a bag left and have since switched to Nicoletti for espresso, so I was hoping to find another use for it.
LMWDP 267
- slybarman
I had it a few weeks ago as lattes and I enjoyed it very much. It had a smooth but chocolately flavor. The flavor was more muted than Lusso GMC, but quite pleasant. Sorry, to hear it wasn't as good as straight espresso.
I'm going through some right now and I like it. However I seem o be having more spritzers with it than I've had with anything in quite some time. In a effort to get rid of them I stretched out the preinfusion based on a post somewhere on these forums. For the most part it has worked out well and I've had a few great shots along with quite a few very nice lattes.
my shots dialed in around 18:36 with a 15 second preinfusion and 40 seconds total.
I did have one latte in particular that fit a common description that I have never tasted quite so perfectly before..."tastes like a snickers bar". Never in all the time I've been making coffees have a had a cup that so perfectly fit the description.
LMWDP #641
I bought a bag recently too and am also fairly disappointed with it as espresso, I actually enjoy it much more as filter.tv79 wrote:I'm in the same boat. By no means would I consider it bad, just wasn't quite what I'd expected.
