Cleaning a Mazzer Mini
KarlSchneider
#1: Post by KarlSchneider »
I recently asked an espresso machine sales / repair firm
"I have had my Mazzer Mini for 3 years. I grind less than a pound a week. I assume I do not need to worry about new burrs yet. is there a cleaning routine I should follow?"
<Reply>
"As for the Mazzer, I would suggest leaving a good thing alone. One customer just tried to clean his Mazzer grinding chamber, and he is having the most difficult time putting it together.... Grinders in general do not need any maintenance unless you are in a coffee shop setting."
I welcome suggestions from readers of this forum if they recommend a routine. I have read about using expensive cleaning materials from Urnex and other things. I suspect I have ground no more than 150 lbs of coffee in my Mazzer so far which is well below their burr replacement suggestion (I think it is 350#) but that may apply to cafes and not home use.
I am interested in general maintenance as well as burr replacement.
Thanks for your help.
LMWDP # 008
Admin
#2: Post by HB »
The thread Urnex Grindz Espresso Grinder Cleaner offers opinions on the subject, including the usage of rice instead of Grindz. I've heard the same advice as your repair firm's, probably because they worry the owner will cross-thread the burr carrier. The rice-once-a-month routine satisfies most of my neatnik urges; I'll remove the burr carrier for inspection once or twice a year. At least for the Mazzer, the difference between one week and six months of trapped buildup isn't readily apparent - what the rice (or Grindz) doesn't get is redeposited post-haste.
According to the owner's manual, the Mini's burrs are good for 300 kilograms of coffee. When the day comes to change them, it's a 10 minute operation. The tricky part is the upper fixed burr assembly "floats" on three stiff springs. These springs push the upper aluminum cast assembly against the chromed steel collar. That tension is good for keeping the setting firmly against the top of the threads (no slop) and prevents the collar from moving, but means you have to push against three springs to rethread the collar. Some owner's cross-thread, especially if they have trouble finding the first thread's engagement point or forget that it is reverse-threaded (counter-clockwise is tighter).
Hint: If you mark the disengagement point on the collar with a felt-tip pen, it will be easier to rethread later (i.e., to rethread, set the collar gently on top of the threaded chamber, turn it past the point of engagement until it "drops" into the first thread, then reverse to engage the threads). Again the tricky part is holding the floating burr assembly down far enough to allow you to engage the threads while they are not under tension (you could drop a tamper into the throat of the grinder and ask a second person to push down firmly).
My grinder hasn't been opened up in awhile. Tomorrow I'll take some before/after pictures after a Grindz treatment, then you can decide for yourself it it's worth the trouble. I will also snap some pictures of the disassembly / reassembly.
KarlSchneider (original poster)
#3: Post by KarlSchneider (original poster) »
Dan,
Thank you for the link, the description and the encouragement. I should have done a search but did not think to do that.
I may get the courage to take the burrs apart. As you undoubtedly have gleaned i am far more comfortable on the subtleties of the aesthetic side of espresso and machines that I am on the complexities of the technology side.
LMWDP # 008
Admin
#4: Post by HB »
You may want to avert your eyes, this isn't pretty. I've been slacking off lately on my grinder maintenance, as you can see from the buildup on the upper burrs:
Upper burrs before cleaning
Lower burrs before cleaning
The grinds adhered to the upper burr's sides, forming a rounded corner of old coffee. The lower burrs fared better, except for the three agitator / ejector vanes, which accumulated a thick smudge of grinds. Bleech. Let's see what Urnex Grindz can make of this mess:
Upper burrs after cleaning with Grindz
Lower burrs after cleaning with Grindz
Not surprisingly, what was caked on stayed put. The other surfaces are shiny and lighter without any evidence of oil buildup; if Grindz is to be effective, looks like you need to use it frequently enough that coffee grinds don't get a foothold. Now that we've seen the quick-and-easy approach, let's review the old-fashioned way, starting with how to remove the burrs.
  • Empty the hopper, run the grinder until the chamber is empty. Set the hopper aside.
  • Important: Unplug the grinder. Don't just turn it off at the switch, unplug it.
  • Remove the safety limiter Phillips screw from the chrome-plated collar. Its removal allows the collar to spin freely.
  • Turn the collar clockwise to remove (it's reverse threaded). Carefully mark the collar at the point the threads disengage with a felt-tip pen for later reference.
  • Clean the burrs with the implements of your choice. I use a small stiff bristle brush, vacuum cleaner, toothpicks, chopsticks, and for the really teenie cracks, a sewing needle. Apply no oils or introduce water into the grinding chamber, and obviously no chemicals of any sort.
As I mentioned earlier, screwing the collar back on can prove challenging because you must push down the upper burr carrier against three tension springs while engaging the threads. You can do it yourself by pushing the aluminum carrier down with the flat of your hand while rotating the collar with your other hand, but I recommend getting a helper:
  • Place the upper burr carrier and collar in position. The mark noting the disengagement point should be an inch or so prior to the start of the thread (i.e., the dot on the collar should be to the right of the engagement point).
  • Place a tamper into the throat of the grinder. Ask your helper to push down. It won't require a lot of force, compressing the springs a few millimeters is enough.
  • Rotate the collar clockwise (remember, it's reverse threaded, this is in the looser direction). The thread of the collar should nicely drop into the thread of the lower assembly. Continue turning just a little further, then reverse to engage the first thread.
  • Remember to put back the safety limiter screw.
Note: The threads engage easily. If you feel resistance, rotate the collar clockwise to remove and try again. Take your time, cross-threading the collar would be a costly mistake!
Lower burr after Grindz and hand cleaning
Woofy
#5: Post by Woofy »
In addition to the tools mentioned, I have found that a good set of stainless steel dental instruments (under $10 a set at http://www.duluthtradingcompany.com) are amazingly useful for this task. I have Duluth's set with the case and tweezers. It's come in handy for everything from working on my motorcycle to refinishing fine furniture and is a real frustration saver.
Admin
#6: Post by HB »
Looking at my "before" photos, it's really inexcusable. :oops:
If you've fallen behind on your grinder cleaning regime like I did, here's another motivation to mark the calendar each month: I noticed that since cleaning the grinder's chamber, my extractions are more even. The vanes not only eject the grinds out the chute, but agitate / remix the grinds beforehand for even less clumping; I can see an extra "fluffiness" in the grind too that was lacking lately.
The owner's manual (of course) doesn't recommend how often the chamber should be cleaned. How often does a good cafe do it? Weekly?
#7: Post by KarlSchneider (original poster) »
Hi Dan,
I finally had time and the courage to tackle my Mazzer. Thanks to your excellent descriptions and photos I managed the whole process by myself. The trick seemed to be to remember that the threads are reversed. It took me a bit to get back down to proper fineness of grind. I may count rotations next time while unscrewing. My top ring disengaged with #7 opposite the notch facing the doser.
Again thanks for the help and support.
LMWDP # 008
IMAWriter
#8: Post by IMAWriter »
HB wrote:You may want to avert your eyes, this isn't pretty. I've been slacking off lately on my grinder maintenance, as you can see from the buildup on the upper burrs:
Just wondering why it's necessary to "carefully mark the collar"....I've got a mark on the collar where my burrs touch...i've removed the upper, cleaned out the lower section and using your push down method, replaced the upper section, being careful to avoid cross threading....everytime, I hit my burr touch mark exactly...not even one notch off...seems like if threading is performed correctly, a mark for thread disengagement would be unnecessary...but if I'm wrong.....
Rob
LMWDP #187
www.robertjason.com
Admin
#9: Post by HB »
IMAWriter wrote:...seems like if threading is performed correctly, a mark for thread disengagement would be unnecessary...
Agreed, it's only a hint. I offered (overly)cautious guidelines because cross-threading the collar would be a costly mistake.
#10: Post by KarlSchneider (original poster) »
IMAWriter wrote:Just wondering why it's necessary to "carefully mark the collar"
Since I started this thread allow me to add that Dan is keenly (kehnly?) aware that we who read these posts have a wide range of skills. Mine are clearly not on the technical / machine side of the spectrum. Accordingly I welcome all these simple (simplistic to many) comments. After two years of neglect my grinder is now clean thanks to Dan's help.
LMWDP # 008
