New Kinu M47 Traveler - Page 20
Yesterday, I test several grind setting and less then fine drip < set 4+0+0 it takes very2 long more than 1-3 minutes, like Radu said Espreso grind size maybe will takes 5-7 minutes, I also get 1-2 stuck beans. I don't see as much static compare to the old Burr.namelessone wrote:I timed 10g at 30 secs. I noticed that some bean pieces can get stuck between the burrs and you need to either grind coarser or feed more beans to get rid of them?,There is also pretty much 0 static / fines stuck under the burrs, which wasn't the case with old set, the bottom would usually be covered in fines. It seems like it's cutting the beans very gently, or something.
My first brew not so good because I grind stale dark roast coffee 250gr just for testing the grind size and after that trying light roasting Rwanda peaberry 15/250 @ size 4+0+0, a bit muddy at the surface area but a bit watery in the cup, the old roasting stale coffee smell and taste present in cup...
I used 2+0 with the V1, but I don't know how to translate old settings to new settings since the thread pitch is different. I agree it takes quite long to grind, though.
Multiply/divide by 1.5
Old thread is 0.75 mm, new thread is 0.5 mm.
Old 1.3 setting for espresso, new setting 2.0
Old 2.4 setting for brew, new setting 3.6
- Shenrei
Quite long times, especially for aeropress times. However the dose is quite large. Over 6 minutes is absurd. Mine is coming on Thursday to test on my M47. A 20g V60 dose will hopefully be tolerable or improve. How does it taste?
- Tim
My regular v.60 15/250, @4+7+2 it takes 1min:02s to grind and 3:00 brew time, after twice watery in cup I try to add more temperature from 92 to 95C, and now the coffee taste so good, no bitterness, more clarity and better sweetness, I agree with Radu this pour over burr had a boost in pour over method, and tastings note separation more easy to detect...
- Shenrei
Good to know! Looking forward to trying it out in a few days.
- Tim
Do you think you could get similar clarity using the old burrs by not tapping the fines stuck to the bottom and throwing them away instead?
Better clarity and sweetness is the benefits of Pour-over Burr in drip method, the downside if you like the mouthfeel in the old burr that ones will be a bit less in the Pour-over Burr, btw I do never tapping the grinder in all drip method in the old burr to reduce the fines in the cup...
