RO water - need to add minerals?
Went looking for distilled water - everybody out of stock. At Target found their "good and gather" brand "processed by advanced filtration and reverse osmosis technologies" Got some. Removed all the water I could from the reservoir and poured in a gallon. boiler level still fills so reservoir level is ok. Works. Emptied a couple cups out of the hot water spigot and boiler refilled, so there are apparently still enough minerals to allow the reservoir-full indicator to work. I have added no minerals (ie sodium bicarb) edit just added 0.4g sodium bicarb.
Or did I get boondoggled?
Life is too short for bad espresso!
- homeburrero
That was probably the case here. It depends on the controller and the sensor but most of them work ok with even a tiny amount of mineral. On some machines, if you use too-pure water it will overfill the boiler. On yours, which I think has a reservoir sensor as well as min and max boiler level sensors I think the most likely effect of too-pure water would be that the controller shuts off the pump and heater, and blinks the lights.kris772 wrote:so there are apparently still enough minerals to allow the reservoir-full indicator to work.
It doesn't say "with minerals added" so I think it's reliably pure, and a good stand-in for distilled in a water recipe. There are FDA regulations about what can be labelled "purified drinking water" that have you covered.kris772 wrote:At Target found their "good and gather" brand "processed by advanced filtration and reverse osmosis technologies"
Down the road you might want to look into the availability of RO or de-ionized at refillable water stations. I currently buy de-ionized at my local Whole Foods for 39 cents per gallon, but the biggest plus is that I can re-use my containers and avoid the container waste. De-ionized is simply RO that has been further purified by ion exchange and is comparable to distilled.
Pat
Many thanks! This was .95/gal which I was happy with but I will check the big store about 6 blocks away from here and see if they do refillable. Cutting plastic waste would be great.
Thanks!
Thanks!
